Does anyone have experience with the use of electroless nickel plate used to control part thickness?
I have an aluminum spacer which is already electroless nickel plated with thickness held to +\-0.005 mm.
I need to hold this part to +/-0.002 mm. I have seen this done in the past for a bearing bore where parts were sorted by bore size and the plating thickness adjusted to compensate for bore size variation. In that case bore tolerance was reduced from +\- 0.010 mm to +\- 0.005. Does anyone know of someone doing this? What is the best tolerance electroless nickel plating thickness can be held to?
