neanderthal mach
- Dec 18, 2008
- princeton b.c.
Yep I think SLK001 has it nailed. With sleeve type bearings, any unusual noise or that squeal is a sure sign of a lube issue. Thinking I somehow knew better than the manufacturer about lubrication ended up costing me a $800 + lathe motor. And grease should never ever be used in place of oil if that's what's recommended. In general, grease is seldom used anywhere on manual machine tools, and for good reason. Grease retains any of the inevitable wear particles and/or contamination such as cutting chips. That literally and vastly accelerate further wear happening simply because it starts working somewhat like lapping does. Oil helps to both lubricate and flush or wash out that same contamination. Or at least a whole lot better than grease will unless it's being used in something designed to use that exact type of recommended lube. Using grease on lathe change gears to lessen the thrown oil and bit of mess is another prime example, it's a real bad idea. A few drops of way oil every few hrs are all that's needed.
Reading through the Machine Tool Reconditioning book just once was more than enough to instantly change my habits about way surface cleanliness and using more than enough lubrication. As well as often enough to help keep things cleaner. I'd bet a lot that far more machine tools are damaged and worn out long before they should be just due to the incorrect or not often enough correct lubrication. Oil is the cheapest preventative maintenance you can do with any machine tool.
