Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
Going thru my pile of chucks I found an older style 4 Jaw chuck that is independent yet I think has a scroll not ring gear and gear on the jaw threads. Independent adjustment via Male square on both sides of the screw, I guess it can be reversed if Male square rounds. Another square slightly protrudes out the face of the chuck that will move all jaws at the same time, also a slot on the OD of the chuck in the same location as the square is opening for what looks like a hex connected to the same shaft as the square universal adjuster on the face. I've seen photos of this chuck and one similar on the Walcot 18X62 tread reply #6. Machined for a back plate but none attached. Square drive ends look to be in good shape, square on opposite end of the screws look unused.
Anyone with an older lathe that wants period chuck interested? Looks to be in good shape. Few slight dings in the face that look to be from sitting around than from use. If interested let me know!
I have quite a few 10" chucks, don't need it!! If there is no interest I have a few large dividing heads I can make an back plate for and mount it. Kinda sounds like work though and I don't need more of it!
