i cant figure out what 11 size inserts to buy 11er 11ir
11ER are for cutting external, right-hand threads. 11IR are for cutting internal, right-hand threads.
Generally speaking, you are going to need two toolholders. One for internal, and one for external. The toolholders for laydown size 11 inserts are frequently too small to take proper helix angle shims, but that's another part you should be aware of if you ever go to a larger size of laydown inserts.
Laydown inserts are available for practically any thread form used commercially in the last 40 years. So, what kind of threads are you cutting? Standard 60 degree threads? British (also metric pipe) 55 degree threads? Full ACME threads? Stub ACME threads? For now let's assume standard 60 degree threads.
You can buy inserts designed exactly for one pitch, or you can buy inserts designed to cut many pitches. The advantage of the single-pitch inserts is that you get both root and crest properly formed, so they are called "full profile". The advantage of the multi-pitch inserts is that you don't buy as many different types of inserts. The disadvantage of the multi-pitch inserts is that they cut a very small root (may not comply with customer requirements, may be bad for part fatigue life) and don't cut the crest at all. In fact, they are called "partial profile". If you want partial profile laydown inserts, look for "11ER A60" or "11IR A60". Those will cover the range of 16-48TPI (0.50-1.5mm pitch). You want coarser threads, you need a bigger insert size. You want finer threads, you need a full profile or a custom insert.
Really, I gotta say, if you know what thread you want to cut, the question of "what size 11 laydown inserts do I buy" practically answers itself. There are three possible outcomes:
1) Not possible to cut that thread with a size 11 insert,
2) Use the partial profile insert 11xx A60, or
3) Use the full profile insert 11xx yyyy.
That's pretty much the only choice you have to make, unless you want to fuss over insert coatings, chipbreaker styles, etc. But those fussy details aren't questions of
size.
