It makes a huge difference, a two stage compressor with the same motor rating will outperform a single stage flat out anytime.There´s a great writeup on compressors from Forrest somewhere here in the forum. Find it, read it.
Cheers,
Johann
Performance (efficiency) as one factor, ballanced with;
How wide a band of usage you anticipate.
If you go deeper into CNC, you might get to the point
where you leave unattended opporations running.
Might be something like this..........
You find a better compressor (efficiency again) on Craigs list.
But it's not quite enough for your highest (peak) maximum needs,
now that you have added the G&L.
SO.
You have it carry the primary load, and have your currant unit
trip in if the new one falls behind.
Now when unattended time comes, you might wish to have
an isolation valveing set-up, to carry the run, but not the
whole shop which may have leakage, that isn't going to be
addressed any-time soon.
Now you use the appropriate unit for lights-out running.
Phil
