I'm looking for replacement bandsaw tires for my vertical saw.
The machine has about a 24" throat depth and is set up with 3 blade wheels to get the blade around the wide throat. (2) 16" wheels & (1) 12" wheeel.
The tires are set in grooves 5/8-3/4" wide with a shoulder for the back of the blade to run against. The tire on the lower wheel is gone and the wheel is chewed up some from the blade.....looks like it's run with the blade tracking way off and without a tire it chewed into the front side of the tire groove.
The tires I can find are quite a bit wider and somewhat thinner that what I have. Is it fairly easy to trim the width down? (urethane tires)
They talk about crowning the tires but I'm thinking that mostly applies to flat wheels on wood bandsaws.
Any advice?
Any advice?
