Thanks for all of this. Yes, "expansion joints" = "sawed control joints". They were cut, just as you say, as soon as they could get the saws on the concrete. It was probably mid 90's that day.
Can you recommend a semi rigid joint filler for the control joints?
Try the products these guys sell:
Concrete Crack & Joint Repair - Watco Industrial Flooring. I've never used this expansion joint filler, but I have used their epoxy concrete deep fill repair on my warehouse floor. I drive a forklift over it many times a day (and have for several years now) and it has held up very well.
Back to the cause of the cracks, this excerpt is from the Portland Cement Association's website:
"In general, if the temperature at the time of concrete placement will exceed 77 degrees Fahrenheit a plan should be developed to negate the effects of high temperatures.
The precautions may include some or all of the following:
Moisten subgrade, steel reinforcement, and form work prior to concrete placement.
Erect temporary wind breaks to limit wind velocities and sunshades to reduce concrete surface temperatures.
Cool aggregates and mixing water added to the concrete mixture to reduce its initial temperature. The effect of hot cement on concrete temperature is only minimal.
Use a concrete consistency that allows rapid placement and consolidation.
Protect the concrete surface during placement with plastic sheeting or evaporation retarders to maintain the initial moisture in the concrete mixture.
Provide sufficient labor to minimize the time required to place and finish the concrete, as hot weather conditions substantially shorted the times to initial and final set.
Consider fogging the area above the concrete placement to raise the relative humidity and satisfy moisture demand of the ambient air.
Provide appropriate curing methods as soon as possible after the concrete finishing processes have been completed.
In extreme conditions consider adjusting the time of concrete placement to take advantage of cooler temperatures, such as early morning or night time placement.
With proper planning and execution concrete can be successfully placed and finished to produce high quality durable concrete at temperatures of 95 degrees Fahrenheit or more."
Link:
Hot Weather Concrete Construction.
I know it's too late to help you, but it may help others. Also, I hope this reinforces to you that your slab is fine, these shrinkage cracks are only cosmetic in nature.
Kevin
