Kharn
- Feb 18, 2018
.......................VS........................
Controller = Oi-TF PLUS
I am not supposed to use the wear offset radius to force my tool to cut exactly as I have programmed it but if I do not put a negative value in the wear radius offset then all my machined radius are out by the size of the tool geometry radius (Rad of insert).
I would not be so paranoid about it if I knew that the Wear Radius Offset did not have a limit (like the Geometry Offset Radius doesn't seem to have a limit) but with Wear Offset Radius the smallest number (to counter the Geometry number) that I can enter into Wear Offset Radius is -2.000 which means I cannot counter the Geometry Offset Radius with the Wear Offset Radius if the Geometry Radius (tool insert) is 2.1 or larger.
Help please?
Is this a parameter issue?
Note...
Virtual tip position (#3).
Tool Data General, Angle (95deg), Nose (80deg).
Touched Tool on pad @ H8=X & H7=Z
