someone else
- Mar 4, 2023
i have the parts in the first pic. and the second is the cross-feed shaft.
the cross-feed hand wheel freely rotates on the cross-feed shaft with the adjustment lock screw (i guess?) fully threaded in to the cross-feed hand wheel.
the tiny dot between the cross-feed wheel and the pin on the right is brass and was stuck in the bottom of the threaded hole in the cross-feed wheel but not into the bushing. i want to presume that brass dot is there to keep the thumb lock screw from damaging the cross-feed shaft. although the cross-feed shaft has a hole thru it where the pin on the far right of the first pic was in. nothing was tight and pushed out easy, but nothing in this setup caused the cross-feed wheel to lock in any adjustment.
clearly the bushing goes into the cross-feed hand wheel center. that part works fine.
the pin does not look sheared off on the ends so am fairly sure that no breakage had occurred, also the other probably will have been severely damaged in the process, maybe. it might take a lot of pressure to shear that pin.
so no breakage presumed and since the current combination of parts does not work, what is supposed to be in the hand wheel for the adjustment lock in to the cross-feed shaft?
any observation? possibly a pic of what i have to make?
thank you
thank you
