NRDock
- Jan 24, 2015
- Central Pennsylvania
Last week I spotted a good deal on a Haimer zero master with the BT30 mount and jumped on it. Unfortunately, my mill has the NMTB 30 spindle and I didn't appreciate the difference at the time of purchase. I can't freely swap out draw bars in my Fray mill. My draw screw is turned with a long hex key which passes through a splined shaft that is smaller than the screw.
The only way I see to use this device is to remove the taper and shorten the small end by about 1/4", then use a 1/2" female to 12mm male adapter. Without shortening the taper, there is no space for any metal to remain between the male and female threads.
It looks like the taper is held in place with a T27 screw at the bottom of the M12 threaded hole. Does anyone know if removing the taper is as simple as removing this screw?
