gecko
- May 30, 2014
- Michigan, USA
Hello,
I am and have been the owner of a Mazak SQT10MS with T32 control for a number of years now. I know enough to be dangerous .
That is, I am an Engineer, but not a programmer. Since I am a small business owner, I would generally have a guy down the street program this for me and then, we could set it up by ourselves on future prodution runs.
Since then, I have been able to program some of my own simple parts. We generally use the machine for prototypes and small production runs.
Well, I have a new small run of a very simply part that I need to get done.
But, the problem is that it has a slot in it that appears is going to require a Manual Mill Process, of which I have no experience with. I have not found a way to do it with a canned Mazatrol process.
I do not have my programming resource right now as he is out on vacation for a couple of weeks Good for him, bad for me.
So, I have the part completely programmed with exception to the slot.
In one attachment, you will see the part. You can see that it is just a simple cylindrical part with hole into the end of it on the axis.
You can then see the slot that I wish to machine with a ball-end mill. This slot is on the center axis and is 7mm in width. It goes straight into the part for a given distance and then exits the part on an angle. I should mention that the material is 303 Stainless.
The next image that I have included is that of the ideal tool path. You can see that the tool goes straight into part on the z axis and exits the part on an angle in the x axis.
I have also included a screen shot of the monitor where I want to insert the MMP. It is right after I complete the drill process.
So, this is where I need help. I have no idea if I am doing this right or not. I assume I need to bring the tool into position in from of the part i.e. 0.25Z and -0.1X ? Is this how I do this? Then, I need to turn on the coolant, turn on the mill tool for cutting, make the straight move on the z, make the angle move on the x and then back home with the tool?
Is there anyone that can help me with programming this MMP? This should be so simple, I just have never done it. Can you help?
Thanks in advance,
Mike
Thanks in advance,
Mike
