shearing will work, but will slightly deform the ends. I shear rod all the time, up to 1", on my 50 ton ironworker.
You can buy manual rod parters, which are made to shear round bars with only a little distortion.
Old US made di-acro-
https://www.ebay.com/itm/386174969987
New Pakistani on ebay-
https://www.ebay.com/itm/3942645709...MI4--onvjnhQMV_BKtBh1gHQ2KEAQYAiABEgKM7_D_BwE
pakistan has a 50 or so year old stainless steel industry, both making it, and fabricating it, so this rod parter is most likely ok, but, its mail order from pakistan, so, you pays your money, you takes your chances.
A cold saw with the right rpm and tooth count will do it too, and they do make semi-auto cold saws that will feed to a stop.
KALAMAZOO NON-FERROUS AUTOMATIC FEED COLD SAW. Single Feed Length: 17-1/2". Automatic Feed. 3 HP Motor. Capacity, Square, Solid: 4-1/2". Capacity, Round Tubing, 90 Degrees: 5". Capacity, Round, Solid, 90 Degrees: 5".
www.ebay.com
there are also these little cnc tabletop cutters, will go up to 3/8", not cheap, but less than a new auto coldsaw.
