Hi Cal.The splines take all the torque on the large bevel gear.I will take some pic`s with bevel gear on shaft.There was only a piece of felt under the grub screw.Did seem weird.The small bevel gear in casting seems to have thrust plate or thust bearing behind bevel gear and set by nut and and tag washer on opposite end off shaft.The shaft does move appox 3mm once nut is loosened so when I get small bevel gear off the unit will slide out. I want to get gear out as it has a few burrs.The large bevel gear unit has shims under the flange to set correct clearence between gears.I have little dental mirrow and will have a good look.With the collet, the largest taper is a MT 2. I could possible bore it out once I get under case hardening and then have it - finish ground to fit parrell shank for Er 32.The problem I will loose a bit of hight.The correct split collets would be better but all my cutters are metric.Cal if I mispell or use the wrong Terminology please bare with me as I do have dyslexia.You are being a great help and I am very greatful for your time.Regards Phil Smith
Cambridge UK incase a few more VN 1v`s pop up and we will know where they are.[/QUOTE There is a brass key that slots into a grove,held in by grubscrew.Key has been damaged and jamed into up position to release shaft.Someone used loctite to keep bearing in place.Not to sure how hot to take casting to release loctite before doing any damage.
Pictures by carphil13 - Photobucket
