Hello everybody!
I just bought a MH 300C with Philips 432, worked when I loaded it at the seller but when I plugged it in at home the hydraulic started one for about 2sec then nothing happening after that when I press the hydraulic button, like an E-stopp is pressed.
It has three E-stop, one on the panel, one on the side of the cabin and one on the handwheel, when I press the E-stop on the handwheel the actuator clicks in the cabinet but the other two is dead, no actuators respond to those two.
The TRK6 show FUL error.
Anyone have a clue on what could be wrong or what I should check?
I'm new quite new to this, haven't used a CNC mill/lathe for about 20 years, and that was in school...
When I first plugged it in, the monitor was crazy, looked like matrix with flimmering screen and completely unresponsive.
After a couple of hours the screen begin to work properly
I tried to change the order of the phases if that should be the problem but that only showd more error on the TRK6 module.
Is there some glass fuse that I could have missed thats broken?
I have run the diagnostic but can't find anything that looks odd compared to the manual.
Please give me some suggestion on what could be wrong or what I should check.
