crashtestdummy
Hot Rolled
- Apr 25, 2006
- Cedar City, Utah
I have dozens of squirrel cage fans that run 24-7. The motors get replaced fairly regularly, which is to be expected. The ID on the fans gets oversized and I have drilled some out and added and sleeve with a thru hole for the set screw. This is a pain in the rear to do. The question is there an easier way to repair a squirrel cage fan ID? Fan ID is 0.50" and there is room to go to a least 0.625". Thanks.
