Keith Guitars
- Jul 4, 2010
- Woodstock, NY
Hey everyone,
Hoping to tap the collective wisdom on this one:
I've got a 1HP/3ph tool I'm looking to drive from 1ph with a Teco FM50.
Due to the shape of the machine, there's no easily reachable place to mount the VFD, so I plan to use the existing switch wired into the FM50 control terminals.
However, my question is this: the unit has a cooling fan, and constantly pulls air through the housing. In my dusty woodshop, I'd rather not have it operating nonstop - also, the noise would be annoying when I'm doing quiet work.
Does anyone know if the VFD will object to input power being cut while under load? The booklet says the inverter should not be turned on or off using main circuit power - is that just "play it safe" instructions, or will it burn up the drive?
I'd considered putting a 20A toggle switch on the 1ph input, and using that as an "off" switch for the whole system.
It could be mounted right next to the built-in switch - powering up would be a very quick and easy 1 - 2.
Obviously, I'm also trying to avoid having to push multiple switches every time I want to turn the machine on and off. This may be inevitable, but a single off switch would be charming, and the toggle would accomplish that as long as it didn't harm the drive.
Looking forward to everyone's thoughts - thanks in advance!
Best wishes,
Martin Keith
Martin Keith Guitars
Best wishes,
Martin Keith
