Glenn Brooks
- Nov 16, 2014
- Woodinville, Wa
Looking for proper procedure to remove the spindle and gearing on a 1950 S-M 12x48 'Utilathe'.
My lower speed gears are really worn and making a lot noise, so am considering replacing the gears.
However, previously, when pulling the bearings, i could not see any apparent method to extract the spindle, back gear shaft and gears. No room to remove everything as an assembly, and no apparent method to pull the gears inside the headstock casting.
Anybody know The correct method to disassemble?
Thanks
Glenn
Thanks
Glenn
