Anchor
- Jul 12, 2004
- Saxonburg, PA
The machine always worked well for me, I am not the original owner. Production runs are not my niche at the moment so I would like some extra room around the shop. There is an issue with the X axis encoder, I've heard that this is a common problem with these machines. The machine boots up fine but will not align axis because of the encoder issue. I can arrange loading of the machine.
Asking $6,000 or reasonable offer.
anchormachine725 @ gmail.com
I took this info from another website.
EQUIPPED WITH:
Cincinnati-Milacron Acramatic #850sx CNC Control
CATALOGUE SPECIFICATIONS:
Table Working Surface, W x L 17” x 34”
Table Load Capacity 1000 LBS
X-Axis Table Longitudinal Travel 30”
Y-Axis Saddle In/Out Cross Travel 15”
Z-Axis Spindle-Head Vertical Travel 20”
Spindle-Center to Column, Maximum 16.5”
Spindle-Nose to Table-Top, Maximum 26.5”
Spindle Taper, V-Flange #40 CAT
Spindle Speeds, Range 60 to 8000 RPM
X, Y & Z-Axis Feeds, Infinite Range .100 to 480 IPM
Rapid Traverse Rates, X, Y & Z-Axis’ 480 IPM
Floor Space Required, W x D 7’10” x 7’1”
Overall Height 8’4”
Weight, Approximately 8000 LBS
EQUIPPED WITH:
Overall Height 8’4”
