WizardOfBoz
- Sep 30, 2006
- SE PA, Philly
All, I have been trying to do lathe stuff without a proper, working lathe. I've asked how to do lathe stuff (like opening a 1.62 ID aluminum tube to 1.64) and folks have said "Gee, why don't use use a lathe?". I have a Monarch 10ee in very clapped out nonfunctional shap, an A___s (a lathe not to be mentioned here) in pieces, and an old Delta woodworking lathe. The latter does have a jackshaft and so I can use it for light, non-ferrous work (like removing 0.01 from the id of an aluminum tube). It also has a compound slide, designed just for such work. The problem is that it has a lantern type tool post. Rather than invest in a boring bar holder for that tool post, I was thinking of buying a proper QCTP. Others have done this, and so I'm pretty sure it will work.
My question is whether to buy an AXA or BXA post. The vertical distance from the mounting surface on the compound to the center axis of the spindle is 1.5 inches. Shars gives the range for the base to the point of the tool AXA post as 0.94-1.67" with a 1/2 tool and CCMT insert. For the BXA, that distance range is 1.13-2.14" with a 5/8 tool and CCMT insert. The BXA would seem to bracket the 1.5 inch distance better. Also, when I get my A___s lathe working, it is better suited to that lathe.
I'm leaning BXA. What am I missing?
