Panza
- Oct 23, 2005
- Lillehammer, Norway
Used tombstones. The boltholes in the tombstones are for M16 bolts, which looks about right for a 500mm pallet. The only problem is that the pallets have 14mm T-slots, so M12 bolts is the max that will go in.
M12 looks kind of tiny for the tombstones, but there will be 8 bolts on each pallet, and the pallets are made like that so it must be ok .. ?
I have figured 3 ways to fix the problem. All of those end up with M12 bolts holding it all:
- Make sleeves for the tombstone and just use M12 bolts.
- Turn and retread the bottom of M16 bolts to M12.
- Make custom bolts with 16mm shank, taper and then M12 threads at the end.
