Wanting to build a gantry crane for my Dad and me to use in the barn. Likely will not be used for anything above 1-ton capacity as our hoist is a 1-ton. Planning to build it to 2-ton capacity due to only a slight increase in the price of a beam and the ability to lift more in the future if necessary. Planning on roughly a 10'x10' opening inside. Found that for this size I will need an S8x 18.4# beam on https://www.lkgoodwin.com/more_info/a_series_gantry_crane/a_series_gantry_crane.shtml
However, I am unsure of what size posts would be required to support this. The plan is an upside-down "T" shape with diagonal gussets going from the horizontal tube to the vertical tube. Also will have castors mounted to each end of the horizontal tube. My mind went to using 3" square tubing with 1/4" wall thickness. My question is if this size of tubing is appropriate for the desired weight rating?
Still new to designing and fabrication but know that I have the ability to make this. Just unsure about material choices.
I appreciate any input
