mchlfranko
- Mar 23, 2020
Has anyone had any luck with the digital version?!
I crashed my digital 3d taster in Z, the tool dropped from the spindle and went down perfectly centered, it actually shoved the tip into the threaded connector. I get an error of 0.004" or 0.1mm when touching off a 123 block. The tip was centered up within a tenth. I took a look and found a single brass screw with a small shaft on it hidden in the back of the probe behind the sticker. As you can see it is badly bent. Haimer said they won't supply parts. I can straighten it out or make a new one maybe.
Any help would be appreciated!!
