Paolo_MD
- Apr 6, 2013
- Damascus, MD
A thought / question related to running two tools at once: Are the additional motors additive to the overall capacity, or subtractive, or neither?
IOW, I seem to recall reading that if you had a 5 hp converter and used it to start a 3 hp motor, and let them both just idle, I *think* that you would have roughly the equivalent of an 8 hp converter. But what if the second motor is under load ... would you still have 8 hp of capacity to start, say, a 6 hp motor, or would you be "using up" 3 of the 5 hp, leaving only 2 hp of capacity to start another motor? (I realize the math is surely not nearly that simple, what with losses, but let's keep it simple for my poor brain ...)
In very rough terms, you can vision each running motor as the equivalent of a flywheel in terms of keeping the three phases at the proper angle between them and as for balancing the manufactured leg. Therefore, the more motors you have running, the better and the easier to start a larger motor.
In terms of total load permissible, it depends on the wiring and the components making up the RPC. But, in general, it's ~3-4x the rated power of the idler.
Paolo
