We have a mazak 5 axis. Currently the rotary table is disconnected cause it has its own issues but the machine is not homing out. When the machine powers on, regardless of the position of the machine. It will recognize that position as 0 for x y and z axis. If I select home and move any of the axes in the negative direction they move at the feed speed and will keep going and crash unless stopped. In the plus direction the machine moves slowly regardless of the set feed speed.
This issue started because the machine has as alarm 9 absolute position malfunction (&00000001, &0017, ) and with that error the machine was still homing out and knew where it was. But I found something online that was supposed to get rid of the alarm. It asked me to home the machine, change parameter M18 but 7 to 0, power off and power on, then change parameter M18 back to what it was, then home machine again. This fixed the alarm until I power cycled the machine. Then the alarm was back and the machine refuses to home.
Any help would be appreciated, thank you
