Trboatworks
- Oct 23, 2010
- Maryland- USA
So- being a complete Luddite- I lost the fight with trying to get a tire to stay put on my old Walker Turner Band saw.
I tried standard then urethane with no luck as the things were creeping around and causing problems.
One day out of desperation I just took a couple of wraps of blue painters tape around the rim and called it good- a year later and the saw is still running fine and it seems to have lost all of the funny shudder the tires were causing.
What's up?
Tires over rated on band saws....LOL
I am running the Lenox Tri-master 3tpi carbide tooth blades- I had thought the wheel would get cut or the carbide chipped but no problems so far- better lucky than smart?
I still have a traditional tire on lower wheel which seems to be staying put.
I cut lots of aluminum on the saw and have even started chopping up some stainless (at wood speed...- not sure I can recommend this), and the top wheel is less trouble as there is no tire to grab chips.
I haven't messed with straight metal saws much- do they even use tires?
What's up?
