Hi All,
This is my first post and your opinions / help is wanted.
We are looking at a contract to manufacture approx. 500+ large sleeve's from low carbon / mild steel with the below dimensions.
At this stage the best raw material size our supplier has offered is (approx.) 380mm / 15" OD x 200mm / 8" ID x 280mm / 11" long so approx. 170kg / 375lb for each piece of raw material.
This will need to be machined to final size which has a flange at one end.
OD of Flange End = 350mm
OD of Bush Body = 280mm
ID of Bush = 220mm
Length of Bush = 266mm
There are also grooves in the bore that require machining along with bolt holes and threaded holes on the flange end so live tooling will be required. I have attached a basic sketch to give you an idea but cannot share official drawings.
My question is, based on your experience, what type of machine and which brand and model do you think would be best suited to the manufacture of these parts? Budget is +/- USD 200k.
ID of Bush = 220mm
- CNC Lathe with live tooling? If so, which brand & model?
- Vertical Lathe with live tooling? If so, which brand & model?
- Mill Turn? If so, which brand & model?
