Homebrewblob
- Apr 5, 2020
- Cincinnati
Me and my brother clean commercial kitchen exhaust hoods and fans in addition to our usual maintenance tasks.
We use a dewalt 4000psi gas pressure washer fed from a garden hose (customers water supply). The pressure washer is bolted to the floor of a panel van, next to it is a NORTHERN TOOL diesel water heater bolted to the floor as well, there’s a 90 degree double wall elbow on top the heater to direct the exhaust out the back of the van. The max temp on the heater is 250 degrees and we run it maxed out 100% of the time.
Works GREAT never had an issue so far, the heater is very good quality.
The pressure washer feeds the heater so no issues with the pump.
We regularly run 100’ to 200’ hoses from the van out on top of restaurant roofs and inside the kitchen. even in the dead of winter Through snow, the water coming out of the wand is HOT HOT HOT.
It does take a few seconds of shooting into the sky to see the hot water show up but once warmed up she’s ready to blast.
When you let off the trigger you can hear the burner shut off, and once your back on the trigger the burner relights!
