dalmatiangirl61
- Jan 31, 2011
- BFE Nevada/San Marcos Tx
After replacing the heating coil on mine ($$$), it was replumbed with disconnects so I can blow compressed air thru it to clear the water. My coil is horizontal, probably/maybe easier with a vertical coil. First connect air and blow the bulk out, disconnect and let compressor recharge, this gives time for water to pool in low spots, then connect air again. Repeat until you are sure all moisture is out. I store mine dry, but only because it is so dry here that metal barely rusts, in a more humid environment it might be best to fill with antifreeze.
