agree .. With swinging and additional 15 degrees one would get 45 on one side...
So back to what is said back in post #7 good to look over a protractor to see a/about 29 - 30* to then know how your compound is numbered.
This is another good thought I did not consider.
I was engaging the half-nut when No. 4 came around.
I have a deft feel for engaging the halfnut and start to move the lever about halfway right before it hits my number and then "feel" the halfnut engage the lead screw into full engagement.
As opposed to just slamming the lever into engagement right before No. 4 pops up.
BUT- Knowing that using any whole number I could also engage on number 1, 2, 3 or 4.
I sometimes will engage on number 3 if I get tired of waiting for number 4 (70 rpm is slow).
I know what the lever feels like when it starts to catch on top of the leadscrew instead of in the lead screw (threading on top of a thread).
The tool tip/ insert is square to the chuck.
I did not square to the piece being turned because it is held by the 4 jaw with the part dialed in with no runout.
Therefore the piece itself square and inline with the chuck centerline.
I do not believe the part was not deflecting because I was turning between centers with a steady rest.
My live center has zero deflection/runout on my indicator - the needle on the gauge doesn't even bounce while spinning.
So----
The toolbit is square -perpendicular all that good stuff.
I'm thinking:
I possibly did not engage half nut on the same number 4. Maybe used No.3 on last few passes. (should not matter)
Or my 29 degree setting was not true 29 degrees.
I have not ran into this before hence the posting.
I've ran some equipment and done many setups.
Ran Akebono, Fadal, CNC in G code- Hardinge, Colchester, Bridgeport - Manual. Blah Blah Blah
I know many of the tricks this and that and am excellent at math.
and suddenly it looks like I used a an 80 degree cutting tool to cut a thread.
Tripped me out!
So of course I posted knowing even with what experience I have, I'm not in manufacturing any more and many of you have more experience and may have done or seen this before when I have not ran into this problem in the past...
Whatever mistake it was I had not made this mistake in 25 years.
So- Screw it Im gonna Pythagorus the whole thing.
Set my compound take a cut and figure the long leg in relation to the hypotenuse.
With this method one could set their compund to 29.1 dead nuts if they wanna.
Just didn't wanna...cuz I have an angle checker and used it instead.
NOT my stamped in protractor since yeah they are close but not close enough.
Might be my angle checker is off a degree. Guess I'll have to send it in to the Dept. of Weights and Measures.
Regardless
I am grateful for all your guys responses and the problem has been resolved.
The compound feed angle was not less than 30 degrees - simple as that.
BTW - this was not a customers barrel but a scrap barrel used for checking and changing setups such as when changing from 3 jaw to 4 jaw and setting up new tooling.
And I'm glad I ran the setup to discover the problem before hand.
I always run a scrap piece and dial things in before running a new setup.
The T-15 insert with toolholder was a new tool I was trying out.
Was hoping it was not the tooling. (I did contact the Mnfg to ask their opinion yesterday to double check if their insert I was using was right for the material being cut).
It's all good fellas.
