M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
We Have an old Air/Acetylene Turbotorch rig that was set-up for Air/Propane use awhile back by switching to a different regulator. The only identifier I can find on the handle is a "C4" and that leads me nowhere online. It looks like all the other Turbotorch acetylene rig handles out there with the quick change tip socket, but instead of having a dial knob on the base it has a thumb button in the middle. Problem is that the button doesn't shut anything off and leaks gas in mid position. I assume it has some kind of bad seal or something, but it doesn't leak with the button in the "on" position and works fine using the regulator and propane tank valve to control things. We mainly use it for odd jobs heating up small parts or soldering. It would be handy if I could fix it but can't find anything related to parts or repair for these things. Are they meant to be disposable?
![20240116_175356.jpg 20240116_175356.jpg](https://www.practicalmachinist.com/forum/data/attachments/364/364472-f3b7248267b30f5a7038071090ac762f.jpg)
![20240116_175411.jpg 20240116_175411.jpg](https://www.practicalmachinist.com/forum/data/attachments/364/364473-473ba0e092397f3878b7f9d32dd68737.jpg)
