chippinchunks
- Oct 11, 2016
- San Diego
Hello all
I have a small benchmaster vertical mill that I use for light work. It works well for its small size but the milling head starts to make noise if I don't keep it filled with grease. I use high temp synthetic bearing grease because that's what the previous owner had been using. I grease the mill head through a zerk fitting on the top of the support shaft to lube it up. Usually after a couple pumps the rattling sound from the mill head goes away but after the mill head heats up it tends to throw the grease out through the bottom of the spindle. Soon after it starts making noise again. I was hoping to find some info on this milling head so I can determine the proper way to service and lubricate it but endless online searches have yielded nothing. I provided some pictures below of the milling head. It uses 1A or 3C collets (both seem to work fine) the only numbers I can see on the mill head are SG-135 other than that I'm not really sure how to ID this thing. I know it's not the original milling head for a benchmaster mill but this is how I bought it. Any help would be greatly appreciated. Thank you
Martin
l![20190129_120551-1.jpg 20190129_120551-1.jpg](https://www.practicalmachinist.com/forum/data/attachments/209/209533-f4ebb73f4f81d11311860df9cf3276fe.jpg)
![20190129_120539-1.jpg 20190129_120539-1.jpg](https://www.practicalmachinist.com/forum/data/attachments/209/209534-594651956e4d3a67bab58186dabda5bb.jpg)
![20190129_120609-1.jpg 20190129_120609-1.jpg](https://www.practicalmachinist.com/forum/data/attachments/209/209535-1acd1d4b27ab792084b74eb59088af7e.jpg)
![20190129_120701.jpg 20190129_120701.jpg](https://www.practicalmachinist.com/forum/data/attachments/209/209536-04330e24cd843909ab54d657ab362871.jpg)
Martin
l
