Job Shopper TN
Cast Iron
- May 17, 2015
- Southeast TN
Hello gents.
I have a task at hand and need help figuring out how to do it. We have a Haas TL-2 lathe. For a reason that escapes me, Haas manufactures these machines with a spindle bore of exactly 3.000" - or perhaps even a thousandth or two under. We all know the old adage, a half-inch pin won't fit in a half-inch hole... well, that applies a lot more when you have a 3" bar and a supposed 3" spindle bore.
Long story short, I attempted to make and use a 2.5" diameter boring bar to skim the spindle bore to around 3.060" or so. Enough that a slightly bent or slightly oversize 3" bar goes thru, as it should have been made in my opinion... well, all I got was a lot of rubbing, endless chatter. No good. I believe I may have made the bore smaller in spots due to all the chatter ridges... heh...
So, back to the drawing board. Any bright ideas on how to open this up?
I have looked at a few technical drawings and the spindle appears to be thick enough that this modification would cause no issue. From front to back, with the chuck and end cap removed, the bore is basically 22" deep, if I recall correctly. The spindle I.D. seems to be slightly hard - maybe in the 30s Rc, based off of cutting it only about 3" deep with a short bar.
The obvious answer to me may be, remove the spindle from the machine (if that can be done without damage), set up in a lathe and bore halfway from one side, halfway from the other. But, we will never have time for all of that work, even if it is possible, even if it will aid us greatly on many, many thousand-dollar shafts we have coming up!
So - any thoughts, please let me know.
