greenbuggy
Stainless
- Oct 6, 2005
- Firestone, CO
I've finally got my Lagun CNC mill up and running, and I want to try thread milling with it.
I've checked out some single pitch thread mills, and holy crap are they expensive. Seems to be that the ones that will do reasonably low thread counts are $150+ in carbide.
I don't expect to do too many real oddball threads, but I have one project that is going to require an 8 TPI outside thread, and I don't want to spend $150 to do it.
So I was wondering, since speed isn't terribly important on this one off job, could I slow my feed down and instead of using a single point thread mill, use an inserted threading bar like this one: 12 1 2 Mini Indexable Threading Tool Holder Inserts Set | eBay instead?
What kind of range of TPI does an indexible threading tool have as compared to a single pitch carbide? For comparison the $150 single pitch one I was looking at could handle 6-32 TPI. Link: 1" 6 32 TPI Single Pitch Thread Mill Brand New TiAlN Coated | eBay
I see it says it'll do 16-48 TPI but are there other inserts that will fit to do larger sizes?
I have future uses for thread milling but I'd like to get into it without spending a ton of money if possible, and if possible leave myself open to the maximum range of thread options without buying more tooling
