I was over at my parents' place and was drilling slate with a masonry bit using my dad's favorite drill. It's an OK machine, but nothing to write home about. Unfortunately, it happens to have great sentimental value for him. In the course of drilling, I was hosing down the stone. This blasted water containing powdered stone onto the shaft of the bit. I didn't think anything of it, since no water was getting onto the chuck or drill. Well, the spinning of the bit drew the slurry into the chuck. Now, the chuck won't operate well since it has grit in it. What are my options for fixing this? Thanks.
Common as fly-poop problem in mostly-concrete Hong Kong.
The grit will usually come out without disassembly. Get out all you can with air first, then
hot water and ignorant dishwashing detergent.
Some of what remains jammed will be acid-impervious flint or quartz grains [sand), some the cementitious and mildly soluble lime product binding them up.
Find a container large enough you can get nitrile-gloved hands AND the chuck and key itself immersed in. Fill with about two bucks worth of distilled white vinegar from the foodstuffs section of the supermart and "work it" gently, to free it up. The debris will crack, dissolve partially, or otherwise get knocked about and find its way out.
Now you want to get the mostly-water + 5% or so Acetic acid out. A slosh of rubbing alcohol, then off to WD-40, then kerosene, working it again until it operates smoothly. Spin it up in a pail to get it dry, and you should be good to go.
Only take it apart if this does NOT work. That can be an even MORE time consuming nuisance, and generally an avoidable one. The chucks are not actually that easy to bugger-up unless one tries to FORCE a jam. Or leaves them susceptible to RUST!
Just don't do either.
Going forward, a "slinger" helps. Think ballerina skirt. Any sort of disk, fabric-reinforced or plain sheet rubber is good. Goal is to spin away anything coming up-shank, wet or dry, before it reaches the chuck at all.
