Dan from Oakland
- Sep 15, 2005
- Oakland, CA
I have a Berco vertical spindle grinder that I'm in the process of rebuilding and the previous owner was not too good at keeping his coolant concentration up to snuff. We have had to clean every inch of the base with a needle scaler to remove the fused on grinding fines- even the stone mount for the segmented wheel needed to be cleaned with the needle scaler. this thing was bad- filled the shop vac several times, even after scooping up the big chunks.
I'm considering using a rust inhibiting coating product called Rust Bullet and was wondering if anyone has any experience with it. We have the base down to bare metal and will use Metal Prep on it prior to any coating. Wondering how the Rust Bullet will holdup to coolant. Yea, I know, call the manufacturer, but I thought I would throw it out here also.
I will most likely top coat it with single stage Acrylic Enamel.
Thanks all.
Thanks all.
