Finn_olsen
- Feb 20, 2024
- Enumclaw Washington
I have recently come into possession of an older Kalamazoo 7AW Horizontal band saw. I use to work in a fab shop around larger saws and I'm familiar with how to run them and keep them cutting well, but this machine has me scratching my head. To start, the plug was bad so I separated the wire harness and got the pump detached from the saw, un-seized the pump and replaced the plug, slapped it together and the whole thing ran great, a few taps with a wrench and the pump came alive as well. Everything seemed to run great but after adjusting the arms that hold the blade in place and getting a piece of rec tube in it to test cut, it cut a slight curve instead of a straight cut. I adjusted the arms further so that the bearings pinching the blade would cover more of the blade and I even shimmed the arms so the blade would have a more square cut and I was able to get the cut closer to square, but its still off by about a 1/32th of an inch. I know when I go to cut larger material the cut will only walk off further and I desperately need to get this thing cutting straight for an upcoming project. any tips? additionally it has a new blade and it has coolant running through it as well.
