Cory
- Feb 9, 2007
- Sterling,VA
Hello,
What is the more accurate type 5C collet closer for a 10EE?
Sjogren?
Monarch Draw bar?
Monarch or another Lever closer?
If you were making a small run of parts which closer would be more accurate for cutting to a length? If you tighten the Sjogren and Draw bar different every time does that effect the part dimension? Does the lever hold a better tolerance because it draws to the same pressure every time? The carriage would be locked so it doesn't move as you make your facing cut. The collet would have a stop in it.
Thanks for the input.
Sjogren?
Monarch Draw bar?
