Greetings.
I am looking for some real world education about compressor tank auto drains. Already watched a bunch of videos, so interested in additional information.
As far as i can see there are 4 types of drains:
1. electric
2. pneumatic that drains when pressure is released to 0. This is what is often used in cheaper regulator dryer combos.
3. Pneumatic that drains when a certain water level is reached
4. Pneumatic that cycles periodically and has parasitic effect on compressor power (uses up like 0.3 cfm).
My compressor is not anywhere near a 120V outlet, so electric is out of the question unless it is 220 and i wire it into compressor plug wiring.
I bought and am playing with group 4 style drain now; just have it temporary connected to drain valve via 1/2 inch hose; so its just sitting on the floor next to compressor. I bought on Amazon: Pneumatic auto drainer for air compressor tank 1/2'' NPT drain valve Compressed air dryer with metal case connecting directly electricity free operation pressure up to 20 par ADTV-69
I didn't initially realize that it would be constantly going off, like once per second. I am now looking at category 3 designs:
Anyhow, what are your thoughts on application/reliability etc of the 3 categories of pneumatic drain valves?
I guess one advantage of the category 4 unit like what i got is that it will release all pressure from the system; i just wish it would go off like 10x less often than its slowest setting is.
1. electric
Brianna Auto Parts - 284412 - Automatic Drain Valve - 12 Volt Heater for Heavy Duty Big Rigs
This one seems to only go off when it fills up with water. May be it will even fit under my eastwood QST 30/60 compressor tank??? have not measured.Anyhow, what are your thoughts on application/reliability etc of the 3 categories of pneumatic drain valves?
