martin_05
- Mar 11, 2009
- Valencia, CA, USA
OK, I've given up on the idea of converting a Bridgeport knee mill to CNC for various reasons given in an earlier thread I started as well as others. I'll get the mill (which is free) and keep it as a manual tool.
I've been bouncing around looking at what to do. Some suggested finding a small used VMC suitable for a home garage installation. I looked around. Frankly, the stuff I've been able to find so far scares the crap out of me. What I mean is that I can see landing a "bargain" that ends-up costing another $10K to fix and really get working.
One idea that occurred to me was to actually build my own machine. I only need it to machine aluminum and be able to go through dozens of design iterations until I can zero-in on a final product design. I don't need to cut steel.
Here's what I am thinking:
I still own a very nice subplate I made back when I owned a VF-3SS. It is made from 2 inch thick MIC-6 and is compatible with Steven's Engineering plates and related accessories. While it isn't steel it is one solid surface to start with.
I already own a bunch of stepping motors, related motor drivers and computers. I'm an EE, so electronics and software are not a problem at all. I would use LinuxCNC. No worries.
So, the idea at this point is to design a steel "cube" made from welded 3 x 3 x 0.25 in structural steel tubing as the frame for the gantry mill.
The base would support what I'll call my subplate. Four columns at the corner would then support a rectangular structure where all the CNC magic would take place. This would be a moving beam gantry, like this but smaller:
Gantry CNC milling machines and machining centers | Memphis/memphis u
In other words, all of the mechanics would be well above the subplate and only the beam would move. A lot of wood router designs consist of a huge bridge that moves back and forth. I can see a lot of issues with this when cutting metal, dealing with coolant, etc.
In looking around for spindles I found a number of options. I might go with a simple 3KW VFD at first just to get going and look at integrating a CAT30/40 setup with a tool changer later on. I'd design the available travel envelope with this in mind. I own a bunch of CAT40 tooling already. However, I don't see a lot of economical options when it comes to putting together a CAT40 spindle (and it has to run off household 220 single phase).
The loose gameplan would be to weld the "cube" and then have the reference surfaces ground flat and parallel. The "cube" minus the subplate will probably weigh in the 400 to 600 pound range depending on construction. The subplate is another 200 lbs or so if I remember correctly (it's got hundreds of holes).
My first level questions have to do with the very idea of fabricating such a weldment. I can weld it together and do my best to keep it all square. It might make more sense to get a welding shop with a fancy calibrated welding table to do it. Then someone would have to grind the subplate support flat and the top of the "cube" flat and parallel to the subplate support. I really don't want to modify the subplate, so the carriage surfaces will have to be parallel to the subplate support.
Well, how realistic is this? I know structural steel tubing isn't machine-grade straight. Starting with 0.250 in walls there's a lot of meat that can be shaved-off to make it flat. At some level I am not worried about that part. Just need to understand the best approach to fabrication. Then again, there's probably something I don't know that will make this a stupid idea. That's where you guys come in. Let me have it. Please.
Thanks!
Thanks!
