Toby.R
- May 15, 2006
- Cornwall UK
I’m running a Molybdenum Disulphide additive with the oil in the headstock of a Holbrook Model C lathe. This uses large bronze bearings adjusted to very small clearance and the manufacturers specified oil is an ISO 5 viscosity hydraulic oil which is very thin indeed.
The spindle runs direct drive from multiple V belts for higher speeds and has a back gear for lower speeds.
I presume that the dynamic oil film will work well at higher speeds but I was concerned that the thin oil film might break down at lower speeds and high load both in the bearings and on the teeth of the back gear (heavy large part – big cut).
I have added the Moly to give a degree of protection in those adverse conditions but now it’s been suggested to me that the Moly will attack copper bearing alloys.
I’ve looked online for real information on the subject. There are various forum contributions warning of dire consequences but little of any authority.
I discovered that sintered bronze bushes often incorporate Moly as a lubricant, that there are ready made bronze bushes with plugs of moly filled wax for lubrication and a reference on the Buntings Bearings site that their aluminium bronze can be lubricated with grease, graphite or molybdenum disulphide.
All that points to the Moly being quite safe.
Is there anyone here with knowledge on the subject (rather than hearsay) who can reassure me that the Moly in oil won’t attack the bronze. I’m pretty sure it’s OK but a little nervous now.
Cheers Toby
Cheers Toby
