I bought the Honda when it was one year old with a bad motor, I wanted a perfect body to start with. Terribly impractical for the street, I was a weight nut and the plexiglass windows didn' even roll down as everything inside the door panel was gutted. Although it was very loud inside I still loved the sound. Probably about an eight inch long driveshaft, my back was a few inches from the tires and the engine was right in front of me. The engine was set back so far that the front injection stack almost cleared the hood, with only about a 1/2" notch in the hood. The tranny was a C6 with a manual clutch in front of it instead of a torque converter. In the picture from behind I had a rear end that was shortened so much that top fuel tires were inside the body lines. There was less space between the tires than the width of one tire. In the wheelie pic that was the more practical racing rear end. I could switch to methanol pretty fast with the hilborn injection. I got the car down to 2350 lbs. and never took it to the strip for a time ET. At high speed it got light in the front and drifted back and forth so I built a spoiler in the fall and by spring my interests moved away fron cars but I still have it although it is in pieces. I have two 427 Ford side oiler high riser engines, one with inj. the other with a blower. If you look close in the picture from the front with the front end off, to the right of the pulleys, there is a power window reversible motor that slacks the fan belt for 1/4 mile runs. The pulleys I made all have extremely deep grooves to keep the belt on when it is loose. A real benifit is in doing this I changed the ratios to run the large fan and water pump twice as fast to keep it cool on the street with the small radiator that I used. It was the first project I did when I bought a new Atlas lathe (can I say Atlas?) Keeping it extreme I went in other directions just as far out there but for fear of being accused of showing off I won't post pics unless someone asks.
That's awesome! I had dreams of stuffing a BB Mopar in a MG midget when I was younger, but spent all my time building other people's toys and never got "around to it"...
