macgyver
- Aug 2, 2012
- Pittsburg, KS
I am setting up a table saw for another shop to run a power feeder and I thought I knew what I was doing... It is a used Powermatic 66 and we have a used Powermatic 4 wheel 1hp feeder on it. We are cutting 8/4 solid wood of various species, blanks are rough cut to length 16-24" long. I want to get a glue joint ready edge off the saw.
My issue that I am having is when using the feeder I am getting a belly in the fresh cut edge, what I mean is, if I put two edges together, there is a gap in the middle. If I hand feed it, no gap. Test boards were 4-10" wide with no real difference in result.
I have the feeder set with 2 wheels in front of the blade and 2 behind. It is angled slightly to put pressure on the fence, not much, just a few degrees. I have the wheels fully on the right side of the blade, same side as the fence. This is also the wide side of the throat plate if it matters. The fence is the factory biesemeyer, with no rear clamp. Throat plate is what came with the saw which is a worn out BB ply pc the previous owner made. The wheels on the feeder are not in good shape, will be ordering new ones soon and I am going to make or get a good throat plate.
My initial thought is the throat plate is the main culprit, but I am not fully convinced yet. I don't want to put a clamp on the rear of the fence as I need to move it often for varying widths. I don't know at this time if the fence is moving anyway. Oh, blade is not new but seems to be sharp, I don't know tooth count or brand at this time, it is a lower count 10".
I'll be back at the end of the week and I plan to work on it. I am hoping some of you guys have ran into this and can help me out on it, I didn't think it would be something I had to worry about as my setup at my shop works.
Thanks,
Jason
Thanks,
Jason
