OK, so I get an e-mail from PM by wardkm123 asking about the solenoid unloader set-up on my MK air compressor. I can't seem to find that posting here, so thought I should address it anyway.
I used a scrap piece of aluminum angle to mount the solenoid to the original unloader position on the cover plate. I wired the normally open solenoid to the motor terminals at the pressure on/off switch. The piping originally to the OEM unloader is now fixed to the solenoid. When the motor is energized the solenoid closes and pressure is fed to the tank as normal. When the pressure reaches shut off psi, it cuts electricity to the motor and solenoid which returns the solenoid to its open position allowing head pressure to drain off so at next start up there is no back pressure to be overcome.
If wardkn123, or anyone else, would like a photo, please send a PM and I will see if my camera still works. Thanks all.
