Snow and ice is slowing things down, the over arms are still stuck, but will move when the temperature is above 50f. So I pulled the ball crank, hand wheels, dials and clutches from the machine to clean up inside. These old mills are pretty complicated with a lot of parts related to the power feeds.
Nothing damaged, but it was time consuming unsticking the sleeves and threaded parts. I used a propane torch and melting bees wax into the stuck parts to free them. The non precision machined and painted surfaces I used a 4" angle grinder with a soft wire brush to clean up. The dials, I scrubbed with a brass brush with the acetone and atf, then used scotchbrite trying to keep the numbers looking crisp.
The war finish on the machine is pretty rough in places, I am working on those areas a little, I bought a big can of Bondo.
Most mills use a long crank handle to move the knee, the handwheel moves the knee with remarkable ease on this machine, the small hand wheel is for the Y axis.
