leeko
Stainless
- Jun 30, 2012
- Chicago, USA
Hi all
I'm working on adapting a dovetail slide from a lathe turret to the front of my van Norman mill, with the idea of mounting a high speed head to it. The dovetail slide will hopefully provide quill-like functionality that I don't have on the van Norman currently.
I've attached a picture of the turret I'm adapting. It's very nicely made, and has almost no wear on it. I'm looking for advice on the best way to add a return spring and a gib lock.
For the return spring, I'm thinking I can machine an adapter to mimic the recess in a bridgeport's head casting, then use a regular bport clock spring to provide the return mechanism. I'm definitely open to suggestions if there's a better way.
For the position lock, I had thought about drilling and tapping through the casting and inserting a lock bolt to bear on the gib. But, it's not really a gib - it's more of a dovetail insert, and is designed to be bolted down with the 4 bolts in the top once any play is taken up. The other side is the same. So I don't think that would work... Any other ideas?
For anyone who's wondering why I'm doing this: mostly just because I can, and I've got some miscellaneous parts that look like they could fit together nicely...
Thanks in advance
Lee
Sent from my SM-N960U using Tapatalk
Thanks in advance
Lee
