OT random observation about size and perspective
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Nov 2014
    Florida
    4,131
    1620
    1941
    Default OT random observation about size and perspective
    Ok, this may get locked, but hopefully get a few replies and some reading...
    Before I started this job, a #10 screw was small, verging on tiny for me. I've done die making, production, job shop, etc, but never to either extreme of large or small, a varied mix in between I suppose. This job our "goto" screws and dowels are 1/16" dowels and #2 and #4 screws. The reason I thought of this was because I have a kit(?) on my desk that has 1 each #0 - #10 shcs, a few different size dowels, etc. Anyways, I noticed my #10 spot was empty. I looked at the #8 and thought "maybe they got mixed up, that looks pretty big" so I calipered the #8 and it was correct, so I went and got a #10 and thought "wow this looks really big!" (LoL)
    I know Tom does big castings and big drills and endmills, and a few guys do the small stuff like me. Anyone do micro-machining? Like lasers and granite lathes and stuff, working on things like .005" ish pins or whatnot?
    Anyone do the tiny stuff and the really big stuff? If so, is it hard to switch back and forth..? Inquiring minds wanna know
  2. Likes Bobw liked this post
  3. #2
    Apr 2004
    Modesto, CA USA
    7,161
    1221
    When I had my datsun I could tell the bolt head size by looking because it was designed that they were all even size heads. To this day I know most were 10,12,14mm. There was one oddball 9mm on a pressure regulator adjustment made by a different supplier.
    My Ford is a weird mix of odd and even so I have to try several wrenches to find the correct size. I am not sure if the battery clamp bolts are metric or English I have seen them called out for both wrenches.
    Wonder if architects and engineers have the same problem from real life to little desk top models.
    Bill D
  4. Likes Bobw liked this post
  5. #3
    Nov 2014
    Florida
    4,131
    1620
    1941
    For example, yesterday the boss told me to put the smallest wire start hole I could, like .007" or so. A couple years ago I would have laughed that off (as in ya good luck), but this morning I am programming that part and going to use a .005" drill, and if that doesn't hold up I will step it up basically .001" at a time until I get to .007-.008" and if that doesn't work we will have to hole pop it, we have tubes down to .2mm. The feature is a cross like shape that finishes at about .009 wide on the 'legs' with a full rad at the end of each.
  6. #4
    May 2009
    Canandaigua, NY, USA
    2,932
    145
    1325
    Well, we use a lot of M1.4 and such, so a #10 is a pretty serious heavy duty bolt.
    https://www.amazon.com/dp/B07KGKFNY2
  7. Likes Mike1974 liked this post
  8. #5
    Mar 2003
    288
    20
    39
    Just finished some electrodes with .003 inside corners. Used a .005 x .046 endmill from Richards Micro-Tool to reach them. The biggest tool we run on the electrodes is the 3/16 endmill we use as a face mill.
  9. Likes Mike1974 liked this post
  10. #6
    Nov 2012
    Wisconsin
    2,109
    3465
    2651
    Most of what I machine would be in the "average" zone.....1"diameter up to 8" diameter.
    The first job I had out of tech school was making replacement parts for steel mills. The "small" parts were 12" or so in diameter.....much of what we did was around 2' in diameter and up to about 8' long. Longest I ever worked on was a shaft that I was boring on a boring mill and was approximately 16" diameter x 20'. Mounted a large V-block to the table and used a hoist to support the far end. We used a carpenters level to get the part as level as we could.....clamped the crap out of it and went to town. (I would definitely say it was somewhat less than an OSHA approved set-up).
    The idea of using drills less than about .05" in diameter definitely gets my attention and makes me scratch my head.....I agree it all depends `on what you get used to.
  11. Likes Mike1974 liked this post
  12. #7
    Feb 2014
    Sunny South West Florida, USA
    3,096
    11127
    3497
    I'm in Swiss.
    One of my smallest parts is about .060"Ø x .100"ish long, with a .035" slot through it.
    When I pick up a 1/4" drill/endmill/dowel pin/whatever, it feels pretty large to me.
  13. #8
    May 2012
    Pittsford, NY
    1,063
    732
    685
    My brother does really tiny stuff. His next to last employer used to make .001 edm holes by the thousands. They now claim shaped holes down to 10 microns with sub micron location accuracy.
  14. #9
    Nov 2018
    Michigan
    358
    171
    198
    We do a wide range of sizes in terms of seals, all the way from big follower seals 40-50 lbs each that I had to lug one/two at a time on my shoulder, using my hands to make sure it doesn't drag on the ground (FWIW I'm a tall guy at 6'3"). All the way down to these little guys:
    For what we actually need to do machining for, 1/2" would be small and 8" would be large. Pretty average sized stuff.
  15. #10
    Feb 2006
    Indiana
    13,015
    699
    3966
    In the late 1950's, I was collecting watches and taught myself to repair them. That led to getting a watch lathe, a bench and a whole bench full of special tools, not to mention thousands of parts that take up very little storage space. If you need tweezers to hold the parts and microscopes to examine them, you are doing small work. Anything else is big.
    Larry
  16. Likes Ron Hofer liked this post
  17. #11
    Apr 2005
    Beaverdam, Virginia
    7,910
    854
    3772
    My range in size is probably 1/2 the size of a grain of rice to something as big as an automobile alternator case.
  18. #12
    Apr 2018
    3,797
    1709
    Gear shops tend to split into either fine pitch (all the teeny stuff) and normal. I can't think of any place that does both except maybe zahnrad. But he's a little off-center
  19. #13
    Jan 2019
    Arizona
    816
    76
    281
    My 1st job ever in a machine shop I was running a HES with a 24" chuck also had a 48" ( I think) face plate. they bought a hitachi 20sII 8 inch chuck it sat there for a bunch of months. So at night I would dick around with it. well they found out and it was mine then along with one of the HES's and a few big manual machines one being the jupiter.
    one day boss came up and asked if I could make a part on the hitachim we only had a 8" chuck and the stock was 1/4" inconel. they were little pressure shear pins with a .014 dia .020 wide groove in the middle rest being about .062 dia. made them about 500 of them over the year. wierd cause I would run 36" dia titanium seals for APUs on the HES 20 feet away and then little itty bitty parts on the hitachi at the same time. always funny as shit one tool on the HES would run 20-30 mins at 10-20 rpm and I would have 2-10 parts made on the hitachi before I had to reload a tool or change an insert on the HES.
    Fast foward 30 years
    now I got a swiss and I love small ass parts, we've made them down to .020 dia .050 long with grooves thousands of 2-56 and 4-40 screws of various shape. most of the parts we do can only be checks on a Comparator and maybe 1-2 places checked with a mic. my 10 " chuck machine just sits there and the citizen and Miyano run daily. on the mill we made parts down to .150 long 0-80 holes and a contour on the od of about .150 dia. we actually make them faster on a Mill than you can do with liver tooling on a lathe. Gotta love mittee bite fixtures.
    most of my mill stuff however is small/ media plates.
  20. #14
    Feb 2004
    peekskill, NY
    24,701
    4736
    10-32? I did not know they made bolts that big.
    IBM (atoms) - Wikipedia
  21. #15
    Aug 2005
    Toronto
    4,936
    3354
    3832
    At work we're starting on a 115' 30 ton double box girder crane & hoist.....at home I'm rebuilding a tiny Levin drilling tailstock to make .003" holes for repivoting watch staffs.
    Variety is the spice of life
  22. Likes sfriedberg liked this post
  23. #16
    Apr 2010
    Wisconsin
    6,153
    4218
    3826
    Quote Originally Posted by EmanuelGoldstein View Post
    You wound me, Sir. I am more than "a little" off-center...
    Truth is, I have been actively making moves toward moving into larger and larger work. ( Both normal machining and gear making. ) But we keep getting new customers ( and requests from existing customers ) asking for smaller and smaller parts and gears. 90% of what we make never makes it to our social media pictures due to NDAs. The recent Segment Gears & Compound Gears that we made are a good example of a small job we were tasked with because they could not find anyone else stupid enough to accept it.
    But then, we have been making arrangements on a Fellows 36 for the new shop, too... If our work load looks schizophrenic, it's because that what we get asked to do.
  24. #17
    Mar 2017
    201
    99
    On thing I've always wondered is why European car makers used mostly odd metric sizes while the Japanese used even sizes. For years i worked on my own cars (Opels, air cooled vws and the last was a 72 Alfa Romeo GTV) and could identify the size of a bolt head on sight. I was very suprised when i tried working on a Japanese car for the first time (90s Subaru) and found 14, 16 and 18mm fasteners where i was used to 13, 15 and 17mm. Kinda a pain in the butt.
    Does it have something to do with choosing a different starting point for preferred numbers?
  25. #18
    Nov 2003
    5,195
    184
    1664
    Screws are made in whatever sizes that are needed. 0000 or 6" diameter, probably even larger and smaller, whatever is needed. I see nothing special about either of them nor of any of the sizes between. Only thing I take notice of is non standard size/thread combinations.
    I have a cotter pin laying around somewhere that is big enough to use as a hammer. The pins it fit were about 3 or 4 inches in diameter and held the ends of guy cables on a 1000 foot tower. I also have some cotter pins that are less than 1/4" long.
    Whatever floats your boat.
  26. #19
    Apr 2018
    3,797
    1709
    Quote Originally Posted by Zahnrad Kopf View Post
    A tiny little thing ! Why go halfway ? I can get you a great deal on a new 2 meter cnc shaper
  27. #20
    Dec 2003
    Washington
    4,758
    2290
    4223
    We don’t deal with making anything really small, but a couple of years ago we integrated and programmed servo loops for 4 stages, each with 50mm of stroke. They were $200k each plus our work of integration and programming and came in just under $1 million.
    The two XY stages work in a vibration isolated vacuum chamber and can move and settle to within +/-10 picometers. They allow an electron beam microscope to creep up on electron orbits to estimate their energy state. Parts from Israel, Germany, and Japan that all required significant scrutiny from the authorities to track where they went and for what use.
    Servo loops clicked along at 20kHz and the operator interface ran on . . . Windoze NT / VB6 . . . talk about a contradiction in technologies . . .
  28. Likes rcoope, sfriedberg liked this post
