We need to design and build a couple small spindles for some grinding operations. They need to be reasonably but not exceptionally accurate: 1 tenth TIR would be perfectly adequate. I have one small Blockhead air bearing that's the right size, but it's overkill for the task and I don't want to risk putting it in harm's way when we usually use it for special measurements. I thought about using a Harig grind-all spindle, but the center height won't work out with the mounting arrangement.
I can design and build a spindle with a couple pairs of preloaded angular contact bearings for this. That wouldn't be a problem. Before commiting to that, I wanted to consider a plain-bearing spindle. Years ago, I had an ancient Hendey conehead lathe with plain bearings that turned exceptionally round. Thousands of SB lathe spindles had plain bearings, and the old Crystal Lake Grinders claimed to achieve sub-0.00001 TIR with their conical spindles riding in scraped bronze.
Can anyone point to a reference that discusses the design of plain-bearing machine-tool spindles in some detail? I've never disassembled a precision plain-bearing spindle and I'm unclear on several details...for instance, how are thrust loads resisted in both directions, and how is the oil-gap maintained as the spindle warms up? It seems like the spindle will get hotter than the housing, which would cause the spindle to grow faster and for the oil-gap to increase.
