It's one of their uses but they offer it for other purposes like in the link. The OP could make a setup using 3/4"Isn't that a brand of coolant hose?
Yes, I could make a setup from raw materials to hold the heaters. But I'd much rather buy off the shelf a robust positioning device that has a base clamp, adjusting mechanism, and mounting stud already assembled and ready to go. Afterall, 3 feet of 3/4" LocLine would cost as much as the entire rig I ordered. Ant then there is a base clamp to source and adapt to the line and the same concerning the mounting of the heater on the other end. It is not a question of ability to make an eventually working device. It's more that the time involved in designing and making a more or less workable prototype and then the fiddling to make the prototype actually work well is more than I'd like to invest.It's one of their uses but they offer it for other purposes like in the link. The OP could make a setup using 3/4"
I have used a heat blanket but it is not convenient/workable due to positioning requirements while heat is applied. The heat emitters work great as long as I can get them into position. The positioner linked by me above comes tomorrow. I’ll report how it works.Could you use a heat mat under the work? Throw a blanket or box over all to capture heat until it warms up. When I pull iron out of degreasing tank I will dry it off with a propane torch so it does not rust. Just wave it over very fast from several inches away. You can see it dry off
I have a golden rod heater under my lathe to stop condensation in winter. I put a heated pad inside the base of my mill for the same heating effect. I control both with one thermostat set to come on at 47 degrees inside the shop. I get condensation at 45 degrees or less. It only runs a few days a year in my climate.
Bill D
That is a very real consideration. Before drawing and printing the part, I plugged the emitter in for few hours and noted the base of the emitter itself got to about 120F---you could hold your hand on it though it felt distinctly hot. The ceramic base is much cooler. I may redraw the adaptor and replace the spigot with a female threaded hole and screw in a standard metal lamp nipple as I think that would be a ruggeder design. I will likely refine the geometry a bit making the 1/4-20 hole a shade shallower, move the wire passage down a bit and thus allow a deeper hole for the nipple.Denis, the first time you use this, you might monitor the temperature of that metal flange to see it stays well below the softening temperature of your PETG filament material. Under 185F should be safe, although it might be a bit weaker at that temperature. Thinking of the pipe-threaded spigot here...
Notice
