I bought a lapping plate and v-block from Daryl and they arrived well packed and in nice shape.
Thanks!
Thanks Josh, my wife told me about your post office troubles, and I'm thankful they found your package.
Here is an updated list if anyone is interested. Feel free to make offers. Click on the link below for photos and more details of each item in the list. Thanks! Daryl
Updated list of stuff on Craig's List
New Rohm MT 5 Live Center $100
New Suburban Tools VB-222 V-Blocks $275
Lot of 50 precision grinding setup blocks and clamps $350
Round Precision ground grinding fixture $50
50 small set-up blocks for precision grinding $75
Small Precision V-Block Assortment + Faith Tool Super Wee Blocks $125
Unique extra fine gage block lapping plate $175
Hardinge 30 taper retention knob fingers $75
Hardinge VMC 40 taper drawbar $400
Marposs T18 lathe touch setter probe $150
Squaring fixture grinding block $75
Unique double sided hand lapping plate with hardened round pins $75
Small flat parts grinding fixture $50
Small round parts grinding fixture with Jacobs chuck $75
Toolmaker made planer shaper gage extended length $125
Precision Ground Angle Plates * Matched Set $195
AA Gage Magnetic Cylinder Square (Pending) $195
Hilger & Watts Precision 5" Level $200
Hold down clamps for non-magnetic (Pending) $50
Pair of scraping masters $200
Hardened and Ground Precision Angle Plate #1(Pending) $100
Hardened and Ground Precision Angle Plate #2 $75
Okuma 40 and 50 taper collet wrenches $150
Morse Taper #4 dead centers $25
Brown & Sharpe #7 Dead Centers $100
Interapid indicator and Moore Tools dogleg $125
VDI 40 test bar $250
New Hardinge Parts Catcher Cylinder $200
Festo SPC200/P01 Control Unit $350
Weiss Spindle Grease Kit for Hardinge VMC $200
Preci-Flex 25 Test Bar / Test Mandrel $250
Stainless Steel Angle Plate $75
Dapra Biax Flaker Blades $75
Biax Scraper Motor with Housing $100
U-507 Unitta Sonic Belt Tension Meter $400
Interapid Indicators $60
Marposs E18 Anolog Gage & A32 LVDT Probe $400
Hardinge GS Series Lathe Test Bars $500
New 6" Chuck Actuator / Ton Fou RCS-6 $500
Vickers Hydraulic Feed Panel $500
Large scraping master 90 degree V $175
New Yaskawa 2HP Variable Freq Drive / Inverter $400
Brown & Sharpe 7743 Mag Base / Suface Gage $25
Set of 3 VIS Poland Micrometers $35
2 Precision Squares, Starrett - Moore & Wright $35
CM 1 Ton Chain Lever Come-along $100
CM 3 Ton Lever Chain Come-along $250
Machine air manifold assembly filter, regulaor $100
Babbit bearing scrapers $10 each $10
Brass flat magnetic transfer plates $50
Long vee magnetic transfer blocks *$175 each
Kitagawa 10 inch chuck soft jaws *New $50
Huron chuck jaws for 12 inch chuck * 12MDR $25
Cushman 15 inch OD chuck jaws $25
LMT Fette Indexable ball nose carbide insert end mills (Make offer)
Cast iron surface plate 18 x 24 inch $200
Mitutoyo 4-36 inch tubular micrometer set $200
0-9 Starrett No 445 Depth Micrometer $75
Trammel points - four to choose from $25 each
Large Lapping Plate / surface plate18 x 22 $125
Starrett No 454 Height Gage 18 inches tall $50
Pair of Ex-Cell-o Test Bars $150
MT 5 Live Center $25
Sandvik Capto C8 Test Arbor NT4000 $400
Parlec 50 Taper test bar / tool geometry setting gage $250
Guhring HSK 63 taper CNC spindle test bar $400
50 taper spindle cleaning burnishing tool $75
