TheBigLebowski
- Sep 9, 2018
Does anyone have experience cutting scroll threads on a 2 axis cnc lathe? (no live tooling)
The width of the scroll would be fairly small - 3mm or 1/8" to keep the tool pressure low , part material would be aluminum or possibly acetal - the parts aren't going to see any appreciable load. Part diameter would be approx 2" with a 0.75" thru hole.
While the scroll could be done on a mill, I would prefer to have them come off the lathe complete with no need for secondary ops.
I understand some of the basic issues (tool clearance with decreasing radius, SFM drop as you move toward the center, low spindle speed req'd due to large thread pitch)
What I don't know about (and could find anything on the web) is if there is ready made tooling available or if there are any guidelines regarding Doc and feeds/speeds
